i know it's been a while, but i thought i'd fill in the keyless group with my progress on the light flash.
i don't know why i always have to try and reinvent the wheel. when i tapped into the wires at the brain, i discovered the hard way that you need to keep the similar colored wires tied together in their 3-wire groups or things go haywire. even the ground wires need to be kept together. when i first hooked up the bulldog, i just tapped into one of the wires for simplicity sake and nothing worked.
i finally got it up and running properly this weekend. lights flash, locks click crisply. i'm a very happy driver. the remote even works from a football field away. much nicer than my touareg that i have to be standing right next to the car.
one final (small) problem. i have one remote that just won't work. i've tried programming it a dozen times. while programming, i can see the lights flash and hear the brain click, but the remote is still dead. i was thinking of trying greimann's technique of unplugging the control unit and plugging it back in, but i just don't have the heart to tear the carpet up again. and then that darn bracket is a real pain to pull out from the car. so that leads me to a simple question.
do you guys know which fuse under the hood controls the wires to the security system? i would imagine that pulling that fuse is a lot easier than yanking the brains out (again!). it's probably labeled, but i thought i'd ask first.
