Threads: 167
Threads: 6
Ok, I just finished my keyless. Awsome, it was just too easy. But, what are the brown and yellow wires. If the alarm flashes the lights when it goes off, don't you think then there should be some way to get access to the lights from the alarm?
Mike
[font=Fixedsys]This is just too much fun!!!
Threads: 77
If it has a wire for each light then you could give it a tru without the relay it will not hurt anyting.
Threads: 44
[quote name='pinball1008' post='58279' date='Aug 23 2008, 04:42 AM']Well I've just purchased the following from ebay
HERE The "Lock/Unlock works great, but I have 2 questions that I hope someone can help me with.
This system has 1 wire for each turn signal, can I wire them direct or do they need to go via a relay? If via a relay, I have a DPDT as per post 20, but can the sender wires be joined together, or not? any help with a wiring diagram would be much appreciated.[/quote]
Pinball, how do you like your keyless entry? I was thinking about getting the same one because having a separate fob reminds me too much of my crappy Yukon and a flip key fob thingy (is there an official name for those?) fits in your pocket better.
Does anyone else here have the same keyless entry? Any complaints?
