11-08-2021, 05:03 PM
4 years ago after some major work (I threw a rod - ugh), my "Check Engine" light was coming on sporadically, usually going off again. Then on again. Had the car checked, fault code showed #31 & #32 - Knock Sensors. Had those replaced. Car fine for a few months and then the engine light again, same knock sensor code.
Here's the weird thing: From a stop, if I rev the car over 3500RPM the engine light goes off immediately, usually doesn't come on again. I did this for 3+ years, and then it was on all the time.
Had an oil change, a few fuses, and a new battery installed 3 months ago and while the engine light came on on the way home, it's been off since. Until today. Reset it manually (drives me crazy when that light is on) and we'll see what happens.
I did a lot of searching for similar issues - ignition switch?
Don't know if it's related, but my odometer and trip meter also don't work. Had the instrument cluster rebuilt 4 years ago, but they stopped again last year. The speedometer sticks and the temp gauge likes to point due north. Until I tap it and then it comes back down. Same with speedometer, a light tap and it bounces to speed.
Also have a weird thing going on with my A/C - sometimes turning it on causes the heat to come on. I just keep switching it back and forth and eventually A/C works again.
My car has only been to a dealer, and specialists in the DFW area but they seem flummoxed as to what the issues are. I've driven this car for 20 years so I know it's quirks. I honestly don't think there's an engine issue and I've paid thousands of dollars in diagnostics.... Being a 968, there just aren't that many people familiar with it.
Any help y'all could provide from personal experience would be greatly appreciated!
