Check Your Codes
I had my 95 coupe in to my mechanic for a few minor service items. The car has been running just great after the cumulative effects of the air box modification, K & N filter replacement, cam shafts properly synchronized after a previous head replacement, and an RS Barn Stage 1 Chip. I also did some exhaust mods where I replaced the rear muffler with 2 FlowMaster Canister units and into a dual exhaust. I had upgraded the steering wheel to the 993 wheel and clockspring (a huge interior facelift modification that I would recommend to anyone!).
Anyway, after the steering wheel install, even though I did the battery disconnect, I got the dreaded airbag light. I asked my mechanic to hook up and clear the code for me, which he had no trouble doing. He also ran a full diagnostic while in there (only $49.00 !!!) and found a fault code with the Hall Sensor. It turned out to be just a bad connection to the sensor.
What I didn't realize is that when the car records a Hall Sensor fault, it automatically delays the ignition timing by 6 degrees !
After fixing the connection to the Hall Sensor and resetting the codes, what a HUGE improvement in performance (feels like a big torque gain and much improved acceleration). As I said, I was pleased with the performance prior to this, so you can imagine how pleased I am now. And all of this to clear a airbag light!
I know it can be very expensive for the dealerships to analyze codes, but as I said, my independent mechanic did it for cheap.
I wonder how many others are running around with missing HP if they have been put off running a code check due to the dealership cost. At $49.00, I think this is something I will have done at least annually.
<!--quoteo(post=71146:date=Apr 30 2009, 08:54 PM:name=Bracer)-->QUOTE (Bracer @ Apr 30 2009, 08:54 PM) <{POST_SNAPBACK}><!--quotec-->I had my 95 coupe in to my mechanic for a few minor service items. The car has been running just great after the cumulative effects of the air box modification, K & N filter replacement, cam shafts properly synchronized after a previous head replacement, and an RS Barn Stage 1 Chip. I also did some exhaust mods where I replaced the rear muffler with 2 FlowMaster Canister units and into a dual exhaust. I had upgraded the steering wheel to the 993 wheel and clockspring (a huge interior facelift modification that I would recommend to anyone!).
I wonder how many others are running around with missing HP if they have been put off running a code check due to the dealership cost. At $49.00, I think this is something I will have done at least annually.<!--QuoteEnd--><!--QuoteEEnd-->
Thanks for the tip. I'm taking mine in today - fourth time in a couple months re: tensioner rod... don't ask. - So, I'll have him poke around and see if anything comes up. Thanks again!
FYI, you can identify error codes for free via the "blink test". Do a search on how.
Rustech
<!--quoteo(post=71178:date=May 1 2009, 01:04 PM:name=rustech)-->QUOTE (rustech @ May 1 2009, 01:04 PM) <{POST_SNAPBACK}><!--quotec-->FYI, you can identify error codes for free via the "blink test". Do a search on how.<!--QuoteEnd--><!--QuoteEEnd-->
Could never get the "Blink Test" to work on my car. Someone else on the forum thought that it may have to do with US vs Canadian spec cars, but I am not sure.
But you still need someone who can clear the codes for you ... I don't think that the Blink Test can do this.
Couldn't get the blink test to work on my car either. US spec cab far as I can tell. I tried it and flash tried it - no dice.
that was weird - did we ever see that light come on?
DME needs to see WOT to initiate blink test. Mine worked ok till one day I couldn't get it either. I noticed the throttle cable was a bit slack. Tightened it to point of only a tiny bit of slack and blink test began to work again. Guess the cable stretches over time.
Bracer - you are correct. Canadian cars cannot do a blink test. But the codes can be cleared by unplugging the battery for at least 30 min.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
codes are not cleared by disconnecting the battery on US cars - not sure about canadian cars
I still have the dreaded Air Bag light but it's on a Canadian car. If I get ambitious I might try the 30 min disconnect; don't really want to re-program the radio/BT/remote again though. I (and others) am organizing a 3 day PCA getaway at http://www.crownisle.com/ that starts this Friday so maybe I will save the frustration until Monday cleanup before I try it.
I guess it will be like the Hershey event I missed only greener [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img] Anyone wants to pop up from WA/ID/OR there is still room. The economy sucks right now so we have 35% less registrants than last year but it will still be about 80 people. But I digress.... [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
Flash - that worked for me last week.
2022 Mustang Mach-E
that's cool - perhaps it was due to the code being intermittent that i have not seen it work here - both times it failed to clear the codes the fault code was an intermittent one - maybe we thought it was fixed, but really wasn't - it certainly does not clear the dreaded airbag fault though
Even though our cars are not OBDII compliant, I believe there are still "hard" codes and "soft" codes, so perhaps a battery disconnect will clear any soft codes.
- Darryl
Last Post by Kim
01-17-2010, 11:43 AM
Last Post by wiseman
08-10-2009, 02:59 PM
Last Post by Kim
04-28-2009, 08:25 PM
Last Post by RPM
12-15-2008, 04:24 PM
