03-02-2020, 06:05 PM
The previous owner of my car bought LEDs from www.sportscarleds.com to replace the instrument cluster lights (just three main ones) with blue LEDs. While I hadn't planned on replacing the stock ones, I decided to give it a try since I was into the cluster anyhow to fix a broken odometer issue. Results (before and after) are below. The lights (before and after) are significantly dimmer in person as my cameraphone was in night shot mode (that or my night vision is worse than I thought). I also covered the light tunnels with reflective AC tape, but didn't clean the original stuff off first, so not sure how much of an impact that gained me.
Before - stock (AFAIK) lighting:
After - Blue LEDs and taped tunnels:
Not a huge difference (other than color) - may switch back to white LEDs and do better repair on light tunnels.
Will need to research the light tunnel issue and see what best way is to clean off original coating (which was failing badly on mine, as shown below) :
Deteriorated light tunnels:
..and my quick "hack job" taping over them with the reflective tape. Same reflective tape shown on top here around edges is covering tunnels where you see the "white" (underside of the reflective tape. Almost embarrassed to post this picture as it's a mess, but I was in a rush and I figured it'd be better than leaving it alone. ;-)
(This post was last modified: 03-02-2020, 06:06 PM by Velocity.)
Definitely not "distracting" as my eyes strain much less to see the gauges now than before. I'd of rather had the soft white LEDs, but just decided to use what i had on-hand....
