Hi All, I'm getting ready to start some electrical mods that will require removing airbag, instrument cluster, etc. I anticipate reconnecting the battery at some point with the airbag out, and I believe the airbag ECU will then register a fault and turn on the dash warning light when I'm finished and have everything back together.
Is there a way to outsmart it and prevent the ECU from knowing that the airbag was out? Alternatively, is there a reasonable way to reset the light without taking the car to someone with the "tool" and paying to have it reset?
I think in some past thread about deactivating the airbag when changing to a non-airbag wheel, there might have been mention about using a resistor or something between the airbag contacts to fool the ECU into thinking it's still there. Has anyone actually done this?
