07-01-2018, 05:43 PM
Like it says in the subject line, as long as the horn relay is connected, the horn in my 968 won't turn off. It started turning on intermittently, reminiscent of the VW van in Little Miss Sunshine (Little Miss Porsche?...), so I replaced the horn relay, and now it's on all the time. The car has a Momo racing wheel, so no airbag (yes, I placed a resistor to trick the system in to thinking the air bag is still there), and I've completely unplugged the horn switch, and it still blares as long as the horn relay is in place. If I have the relay i place with the battery disconnected, I can hear the relay click as soon as I re-connect the battery. I assume the problem was somehow caused by something I did during the install of the Momo wheel, but the problem didn't start immediately afterwards. There must be a dead short between the battery and the horn, which in principle makes it a straightforward problem to troubleshoot, but it's crazy hot in the garage, so any leads on this problem from someone who has seen something similar would be much appreciated. Thanks.
Edit: Just a bit of clarification: As I said, I can hear the horn relay click closed as soon as I connect the battery, but of course the horn doesn't go off until I turn the key to the accessory position. And I confirmed that the horn button is definitely disconnected. So the system is acting as though the wiring for the horn button is shorted somehow.
(This post was last modified: 07-01-2018, 10:43 PM by Cloud9...68.)
