Threads: 12
I noticed from many members under hood photos, that most do not have the factory heat/sound insulation intact.
The insulation is missing from my car as well, and I believe this contibuted to the premature fading of the paint on the hood.
Do most owners remove this material for a purpose (ie underhood temp reduction, clearance, etc), or just trash the material due to age seperation, with no intention of funding replacement?
I just ordered the replacement material and plan on installing as original.
Just curious......................
<img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> Rob
1994 Midnight Blue 968 Coupe
"Speed provides the one genuinely modern pleasure."
-Huxley
Threads: 12
Thanks for your responses, I assumed the factory installed a liner on the 968, as the majority of high end cars have some type of insulation on the hood backside. Maybe Porsche engineering noted some heat retention issues during development, and felt it advantageous to let the hood conduct some heat away from engine bay.
I might give the installation a go and closely monitor the positive and negative aspects relative to the climate, and various driving conditions. I can easily remove it if things don't look good.
My engine installation is currently bone stock (exc. airbox mod), and seems to run on the cool side according to the heater-meter on the instrument panel.
Thanks again for all the information.
-Huxley
Threads: 12
Thanks Flash, I might be able to scrounge up a few temperature data loggers, if not I'll take you up on your offer. Then perform before/after measurements.
-Huxley
Threads: 12
Thanks ds968, based on your experience I'll steer clear of the reflective foil (NASA polyrazmataz) type material.
-Huxley
Threads: 18
I'm very curious as to the results. I have the pads from Jager waiting to be installed for the last 3 years, just never got around to it. If I get to sooner than later, I'll try some temp tests.
89 944 S2 - Promax Chip - sold
92 968 Cab - Airbox Mod, RS stage I chip.
18 Jaguar V6 P380
(This post was last modified: 08-01-2011, 02:07 PM by
DayDreamer.)
Threads: 12
Flash,
The car is in the paint shop so have not had a chance to baseline temperature values yet. I have ordered the insulation and will install them after getting the initial data set.
-Huxley
Threads: 12
Flash,
I have a set from Jager that was never installed. I'm willing to donate for your experiment. Can you wait 'till Ortega Run?
Brian
Threads: 12
flash - shipped UPS yesterday; you should see it monday
Brian
