Hesitation with full tank
Just in the last week, I've noticed hesitation in the engine when the tank is full. Once I burn off a couple of gallons, the problem vanishes. This has been consistent after filling up 3 times now.
Going down the interstate, it feels like I'm deploying a drag chute periodically, for about a second at a time.
Any thoughts?
Chris
1992 Polar Silver Cab - tip, keyless entry, subwoofer, koni adjustables, clear bra (show and touring car)
2006 Marine Blue Cayenne Turbo S - 520HP of fun!
1973 911 RSR Clone Race Car - 2000lb of fun!
clogged breather line? if i had to guess i'd say near the gas cap - in fact, could be the gas cap itself - try removing it and driving
<!--quoteo(post=73618:date=Jun 9 2009, 07:25 PM:name=flash)-->QUOTE (flash @ Jun 9 2009, 07:25 PM) <{POST_SNAPBACK}><!--quotec-->clogged breather line? if i had to guess i'd say near the gas cap - in fact, could be the gas cap itself - try removing it and driving<!--QuoteEnd--><!--QuoteEEnd-->
Good thoughts. I will try the gas cap thing after filling the tank. Would be nice if it was that simple.
Chris
There is a float ball in the tank filler neck...try to look down the filler neck to see if it still intact. fuel may be entering the breathing system/breather tank. Does it happen more on hard left turns?
It does sound like a breather problem when you first describe it . If it continues, also look to a fuel pump or pressure regulator issue
also, there is also an 'in-tank' filter which can get clogged
Last Post by mick968
11-07-2008, 04:17 PM
