I run a 927 in a Bonneville land speed racing class and while the car's been very successful in setting and then resetting the two liter naturally aspirated class, it's run is about over as configured. Therefore I'm considering the installation of what would be a modified 968 power plant in the car. I realize that the engine mounting is different and that the clutch is hydraulically actuated (versus the 924's cable) as well as the ECM issues I'll have to address, but the first question I have concerns the drive train. My life would be immeasurably easier if the 968 will mate to the 924 drive train - specifically the bell housing. In looking at pictures of the rear of the 968 block I've found on line, the shape and bolt placement looks to be the same, but it may only be similar - versus identical. Anyone here know that answer? Thanks for any help!
Rick
