if you have a telescoping dentist-type mirror and a telescoping flashlight, from the top side of the car you'll be able to see under/around the water pump and ID any leaks coming from it or connections thereto.
Coolant would be accumulating on the underside of the water pump -- which you can see with a mirror.
Another source may be the plastic housing of the radiator (where the lower hose from the water pump connects) may be cracked.
If that's the case, it means new radiator.
I've had to replace all of these this year (water pump, <acronym title='heater control valve'>HCV</acronym>, radiator, hoses)
