Help!!!
Hello all and thank you in advance,
I will try and explain as best as possible since I don't have pictures.
On the exhaust side of the motor. There is a hard line that runs along the exhaust manifold and connects to ~2 inch hose near the front of the motor, this hose connects to a plastic device (llooks like some kind of valve). It is this plastic piece that is spraying coolant. I would like a part # if possible so I can order it today from work. Thank you all once again.
The infamous heater control valve! Order from here:
http://www.paragon-products.com/product_p/...0.830.57.84.htm
This would be a good time to upgrade that flimsy plastic part to the metal one which came on the Audi 5000. My autozone part number for the metal heater control valve is 74671 the cover of the box has this number plus the words heater valve and Factory Air on it. It was about $12. good luck, Bob Blackwell.
I know this horse has been beat many tiimes but can someone summarize whether the Audi valve is a direct drop in replacement or do you have to monkey with the hoses and attachment. This is important for someone who needs a quick fix.
So Monkey or No Monkey? <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
It is a direct fit - the only adjustment I made was to straighten out and shorten the vacuum connection and add lip of JB weld for a better seal (minor adjustment) . Also changed out hose clamps - do a search on the heater control valve - there should be a thread on it already
Sam
Thanks Everyone!!! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Mark,
I'm in Sac also and just changed my HCV in january - let me know if need any help or just want to be talked through it...
Sam
[quote name='EEZATOY' date='Apr 6 2005, 11:08 AM']Mark,
Sam
[right][post="2913"]<{POST_SNAPBACK}>[/post][/right][/quote]
were you able to find an all metal part local in Sac?
Yes, Call around to the different Autozones - ask them if they have it and to look and see if its the all metal one - I found mine at the one at the 99 and Fruitride Autozne.
[quote name='EEZATOY' date='Apr 6 2005, 12:09 PM']Yes, Call around to the different Autozones - ask them if they have it and to look and see if its the all metal one - I found mine at the one at the 99 and Fruitride Autozne.
[right][post="2918"]<{POST_SNAPBACK}>[/post][/right][/quote]
I found one, thank you. Us Sacramentans should meet up one of these days.
Josho:
Is there anyway that you could pick up one of those metal HCV's at the Sacramento store and ship it to me. I'll gladly pay the shipping. I just called the store and they have one in stock but do not ship out of state. I live in Massachusetts and have been unable to locate one locally. They tell me that there are none on the east coast. I would appreciate it. If you could email me, i'll send my address, money and whatever else you need.
Thanks,
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
Josho,
Good deal - I haven't had any problems since replacing mine - one less thing to worry about...and yes we need to have a Sac gathering, theres at least 5 of us in the area.
Carl did you and Josho hook up?
Sam
Carl,
I'll take a picture of the part tonight but it's part plastic, and the store I went to it was the last one. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Did you call around to the other Autozone's? I found the metal one at the thrid one I called? Hopefully you can still find one of the old(all metal) ones.
I called the Autozone store at 3333 Fruitland rd. at about 4:00 eastern time and the guy physically checked his stock and said the one he had was also partially plastic and metal.
Carl
Last Post by Swin
08-11-2014, 06:27 PM
Last Post by Lear35A
08-18-2012, 01:18 PM
Last Post by cosimo
10-23-2006, 04:53 PM
