Threads: 12
Has anyone purchased a headlight motor relay recently?
The price quoted from Sunset is $99.xx. Seems expensive to me considering I had seen posts from less than 2 years ago that the relay was running in the $50 range.
Bart
'92 968 Arrest me red Coupe
'71 G-Production 510 #61
Threads: 12
I don't think those are the same relays that I am looking for. The one I need is located at G17 and G18 in the fuse box. I will have to go look but I think it is labeled as control unit light combination. Maybe headlight relay isn't the correct term.
Thanks for looking 968 Cab.
Bart
(This post was last modified: 07-11-2005, 08:19 PM by
Bart.)
Threads: 12
[quote name='968 Cab' date='Jul 11 2005, 11:03 PM']oops. you're right Bart - I'm so used to working on 944 and 951S that I forgot that the 968 HL relay went into the fuse box instead of on the HL motor.
hmm.. if the relay is suspect anyway, I've had a LOT of success cleaning the relay contacts on these cars. With plastic covers on that unit, it is pretty easy to open it up. I use a thin 1/4" wide strip of 1000 grit paper folded over and just run it through the contacts to remove oxidation and arcing deposits. That usually does the trick.
[right][post="7251"]<{POST_SNAPBACK}>[/post][/right][/quote]
Bart
