head lights won't go down
#41
I wanted to follow up on mine.  Mine was intermittent on one side.  I traced it down to two issues.
The motor has a spindle with very small teeth around the circumference.  The spindle rotates 180 degree between ON and OFF positions.
A hole on a brass crank arm attaches to this spindle and the inside of this hole also has small teeth. These teeth a quite fine. To keep the crank arm on the spindle a little bolt screws into the spindle. If this bolt is not tight, the crank can slip the spindle as the teeth are not overly aggressive.  Similar to a windshield wiper arm attached to the windshield wiper motor spindle
At the end of the brass crank arm eventually there is a brass ball joint that attaches to the end of headlight hinged arm.  Upon inspection, my ball joint had some resistance to movement.  Perhaps dirt or a bit or white-ish corrosion on the brass.   I put white lithium grease into the ball joint, moved it around a few times until it moved freely without resistance.    I tightened the bolt going into the motor spindle to make sure the arm did not slip.
So I think the bolt was not tight and the corrosion in the brass ball joint was enough to make the spindle slip.
Works reliably now.
Last Post by Roboman
01-13-2020, 06:48 PM
Last Post by jferraro17
09-27-2016, 02:37 PM
Last Post by 94SilverCab
04-23-2014, 10:43 AM
