04-21-2010, 05:51 PM
I just did some repairs. The cooling fans (behind the engine radiator) sometimes didn't stop turning and drained the battery. Changed the thermoswitch, but no result, thus I replaced the old relay with a new one --> OK.
I changed the old HCV +/- a year ago by a metal valve. The regulation with the new metal version (NAPA) was very bad, switching between all or no heat.
I placed a new OEM type --> OK
The valve-sitting of the metal type was "butterfly". The valve-sitting of the OEM is "sliding-door" --> this explains the difference in regulation.
After 1 year of manuel operating, the electric function for the convertibel top is repaired.
The syncro-cable between the 2 electric engines was broken.
Rack-Tack and StuttgartShift Block are installed a week ago. Changing gears is more direct, I like the tuttgart Shift Block.
For the Rack-Tack --> I don't feel the difference, but I need a new alignment for the front wheels, because the steering wheel is now off middle position in the straight.
After a long search, I finally bought steel lug nuts via ebay. The are the "close type" like the alloy OEM --> It was a bargain.
Overall : our cars can become better and better with aging (or with maintenace and some well chosen mod's).
[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img] [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
