10-04-2011, 04:58 AM
If you remember my problems from Hard starting I through III, the answer was the last place to look. I changer hoses, injectors, check valve, filters, you name it I changed it and the car ran great, but starting got worse and worse. It was so bad I was embarrassed to go anywhere I had to shut the car off and start it again.
Where could the gas go but back to the tank some way. There was never any gas smell or leaking gas, so where did it go? I had a pressure gauge mounted on the fuel rail and every time I shut the engine off the fuel pressure went to zero in a minute. I took the return hose off at the fuel rail and no gas came out of the return on the regulator.
Took the whole system off the engine and pressurized it on the bench. There was the answer. the fuel was leaking, no not just leaking, being sucked out of the vacuum side of the fuel pressure regulator and through the vacuum hoses back into the air intake of the engine.
New fuel regulator and it starts instantly, idles properly and gets better gas mileage. Even the factory manual which has a page on how to track down a fuel pressure problem never said to look at the vacuum side of the system.
Sold
