Fog/driving lamps
I noticed my passenger side foglight was out - replaced the bulb and works fine now.       Also installed some XPEL shields I found on clearance for both headlights and foglamps (which i'm happy I did, after seeing prices for replacement glass for all of them!).
Is my fog/driving lamp the stock one?   Made by Hella?
To my question - the foglight is my light is pointed to in the green area below.    There is another separate bulb/assembly in the red area in the same lamp assembly - what is the function of that light and how is it activated?
The outer are fog lights, the inner flash when you pull the stick to flash some one out of a turning to let the go
This is with the head lamps down
They are also driving lights activated with a switch near the fog lights
You can download the drivers manual from www.pdlibrary.co.uk
Yes dont break them at over $500 each they are a touch on the expensive side, and most of the auxiliary lights are made by Hella
I have 1mm high impact Helicopter tape stuck on mine to help with stone impacts
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
I Have XPEL on Turn Signals, Fog Lamps and Headlights...an absolute bargain!
A good thing is to cover your fog lights with a transparent protective film. This particular area is prone to get hit by rocks.....VERY EXPENSIVE replacement.
Quote:I Have XPEL on Turn Signals, Fog Lamps and Headlights...an absolute bargain!
Waylander I'm in UK for a couple of days to see my brother on his birthday. Is XPEL the sort of thing I can find at Halford's?
DIY is so much more prevalent in UK than in France. I may just go to Halford's in any case as I'll have space in my bag after I've unloaded the French cheese!!
Don’t think you can get it in Halfords, I have never tried
can check the Halfords website for you, are you already here ?
Should  have said something about dates, I could have posted it to your bro
Same here, would like to know how I can find some XPEL as it doesn't exist here. Alternative stuff is far too thin.
Could be useful !
Yep came in at noon to a windy Stansted. No worries, I'll see what I can find. Chap if I find anything useful I'll send it across when I get back. Cheers
Thanks for that offer Waylander, no worries I have plenty of time to potter about, I may even make it to the Porsche to see if they have any of the rubber wedges and bungs I need to replace ..... it is so much simpler for me in English!!
Halford completely hopeless, will look online when I get back to Fr on Wednesday
Quote:Thanks for that offer Waylander, no worries I have plenty of time to potter about, I may even make it to the Porsche to see if they have any of the rubber wedges and bungs I need to replace ..... it is so much simpler for me in English!!
you need pictures, they speak 1000 words,
get a copy of PET running in a virtual machine so you can print pictures
Seen it on amazon
I don’t know the brand of the film I have on the fog lamps but it’s pretty damn thick ..I’d guess at least 3 mm, if not more.. maybe unsightly from very close up , but not bad from a distance . And it has not yellowed in the 20 + years to I’ve had it on, so no complaints .
If those things are that stupid-expensive maybe aesthetics can take a back seat to protection .
In the latest price update
944 631 033 00 LH fog lamp $477.00
944 631 034 00 RH fog lamp $477.00
a small front end shunt that requires indicators, fog lamps, and a PU will cost $3000,00 before labour and paint, in this country enough to write the car off for insurance,
here the companies total your car if the repair comes to more than 40% of its trade value,
That is why I have Stated Value insurance on my 968. Here, a total is 80% of the value, but if you consider that the Blue Book on my car is less than $20,000 it wouldn't take much for them to declare a total loss.
Same here ( stated value policy ) . I encourage everyone with a 968 to look into this , you’d be surprised how inexpensive it is .
And be careful, because insurance companies are regulated at State level , and although typically in many state the threshold is 80 % to 70 % , in some states ( Iowa for example..) it’s as low as 50 % .
Folks: My understanding is that the foglights have 2 bulbs--one for fog (of course), and the other is used for daytime running lights in countries like Canada where they are required. To activate the daytime running lights, one needs the daytime running light module (relay). This was only supplied in cars where DRL were required. It is no longer available from Porsche. They light when you turn the key to the on position, and go off when the headlights are turned on.
Quote:Folks: My understanding is that the foglights have 2 bulbs--one for fog (of course), and the other is used for daytime running lights in countries like Canada where they are required. To activate the daytime running lights, one needs the daytime running light module (relay). This was only supplied in cars where DRL were required. It is no longer available from Porsche. They light when you turn the key to the on position, and go off when the headlights are turned on.
I was able to confirm that the one switch I have is for foglamps - the other light in same housing seem to only be usable in the "flash to pass" scenario.   Haven't seen a way (yet, but haven't looked much) to activate them other than flash-to-pass.     My car is US-spec, so no stock DRL.   Looks like location G26 in relay box in left footwell was location for DRL relay in Canada.
There also a low flat interconnection relay in the middle of the fuse box, can’t remember it’s proper name.
but you can spot it easily it’s only about 10mm high, this little thing is country specific there are loads on eBay all different part numbers
you will need the correct Canada one of those as well as the NLA relay
in some countries the driving lights come on with high beam
Not sure if everybody else has the same configuration, but in my 968 which was delivered to the US, the light module has two bulbs.  The smaller part of the light housing is the fog lamp which is controlled by the rocker arm switch below the rotary light switch.  They are activated by turning the rotary knob to either park lights or headlights and then turning pressing the rocker switch.  The other part if the light module houses the driving lights which may be activated any time by pulling the turn indicator stalk back (to flash them) or pushing it forward to high beam.  One of the best features of the 968 is that high beam not only uses the main headlights but the driving lights as well.  The combined lighting is very effective.  My car does not have DRLs.
What I am interested in though is finding the city lights that I can use in my headlights.  The holes are in the headlight bucket, so I would just need the proper housing and the wiring to connect them to the park light circuit.  The way the hole is mounted near the top of the headlight bucket would allow them to be running while the lights are in the retracted position.
I have city lights on my 911 and really like the look for sunrise or sunset.  Has anyone installed them? They were standard issue on UK or Euro spec cars I believe.
1988 Carrera Marine Blue Metallic
1994 968 Iris Blue
2006 Jaguar XJ8L British Racing Green (35k mi)
2002 Ford Thunderbird, Whisper White
2016 Ram Limited 1500 EcoDiesel
Last Post by Kim
12-05-2013, 08:36 PM
Last Post by PhilG968
04-02-2007, 01:45 PM
09-09-2005, 08:49 PM
