02-13-2006, 10:03 PM
Has anyone had trouble replacing the pressure-side power steering hose (from pump to rack)?
I'm in the process of installing a remanufactured steering rack and decided to replace the hoses while I'm there. The bends in the rigid section of the hose at the rack side are slightly different from my original hose. The result is that I can't get it to fit into the bracket that's supposed to hold it to the rack. Also, the replacement hose is much stiffer than the original - probably an improvement, but it makes connecting it to the pump a real bear and it ends up resting against the block after I've wrestled it into position at the pump (not good).
I got the hose from Paragon and talked with Jason today about the fitment challenges I'm having. He confirmed that this is an original equipment replacement part (p/n 944 347 447 02) and he offered to check his stock and look for any differences. I'll talk with him tomorrow to see what he's learned.
The rack is correct and my old hose fits perfectly. However, I'd really prefer to replace this hose while I'm doing the steering rack project. I don't believe the original hose is leaking (yet), but it looks pretty tired. Also, I'm of the mindset to invest some extra time now to avoid problems or re-work down the line.
Anyone already been through this? Any suggestions would be appreciated.
Thanks!
Thanks!
