11-03-2019, 01:12 PM
On 10/8/19 my '94 968 tried to escape the garage - car was in reverse w/ e-brake on. Did considerable damage to car and house. After being diagnosed at Mayo Performance (DFW area), the following was found (in addition to the below, later discovered the incident burned out the starter as well):
"Attached are a few photos of the cause of all the trouble. The first three photos show the starter, starter connections and the main harness properly secured, bracketed and routed to the starter. Nothing externally visible or obviously damaged. The last few photos show the jacket cut away, revealing failed insulation on the two wires that were sheathed in the same jacket. The larger wire is the main cable that delivers power from the alternator to the starter lug, where the main battery cable is connected, which then feeds power back to the positive battery terminal. The smaller wire in this harness is the solenoid power wire that comes from the ignition switch. It provides power to the solenoid when the key is turned to the spring loaded start position. Any time the solenoid wire is connected to battery positive feed, the starter will engage, and remain engaged and cranking until this connection is interrupted or the battery gives out. These wires, a battery positive and the starter solenoid power, clearly contacted one another due to the failed insulation. The problem has been brewing and must have finally reached the tipping point.
I must say in 33 years of working on all models Porsches, the 944/968 line in particular, I have never seen failed insulation like this. One contributing factor is likely the fact that the jacket surrounding the wires was full of water! These harnesses were set up exactly as per the factory layout, even though the starter was clearly replaced, properly, at some point in the past. I am looking over the factory information we have to see if there was ever a recall, or Technical Service Bulletin (TSB), concerning this harness. The harness itself is no longer available from Porsche, but we have the materials needed to fabricate a new harness for the wires concerned. This is not a case of burned wires, so no other damage is apparent. The issue is isolated the wires in this particular harness, in this particular location. I do need to follow up on other concerns and will get to those today. I just wanted to provide you with my findings at this point. I'm thankful no one was hurt. This spontaneous cranking issue could have occurred before now, but perhaps no one was around to hear it and the car was not in gear? That is just speculation on my part."
Car was fixed at Advantage Autoworks (she's back beautiful!), and they discovered someone else this had happened to with a 968. Same with Mayo - one parts supplier had their own horror story. So definitely something to be aware of.
For me, these were the symptoms that led to this:
-Battery drain, batteries were replaced almost every year the last 3 years
-Check engine light came on sporadically (3 years), seen by numerous Porsche specialists -code indicated knock sensors
-Knock sensors replaced, check engine light still came on, codes again read knock sensors
-Engine light would go off if car went above 3800 RPM
I know those aren't a scientific diagnosis but those are the things I noticed and though I told 3 prominent Porsche service providers (including a dealer) the issue wasn't discovered until a catastrophe occurred.
Just hoping to make people aware and save you some heartache (not to mention $$$).
Pam
Pam
