Threads: 42
Sorry for the bad pic. Its taken leaning over front left panel looking down over expansion tank. Saw this wire/cable just leaning against alternator. Wires on alternator and compressor are hooked up. This wire looks more like a cable. No idea where it goes. Everything seems to be working and no idiot lights on dash.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Where does it connect? Just to be clear ( or try), it is the line that is about two inches from the alternator cable, which looks a little bare in the pic. What symptoms might this disconnected line cause?
There is what looks like a bleeder nipple on the throttle body with nothing connected, might it go there?
2005 Acura RL
2004 Toyota Sequoia
(This post was last modified: 07-16-2013, 12:30 PM by
rl968.)
Threads: 42
It is long enough, easily. I will check it tonight to see if it fits. Do you (or anyone) have a pic of their throttle body, just to confirm?
This is not a hose, it's more of an electrical cable, pretty thin with an expanded connector at the end of it.
2005 Acura RL
2004 Toyota Sequoia
(This post was last modified: 07-16-2013, 12:55 PM by
rl968.)
Threads: 19
Are you sure about it being electrical. The only thing I see in the pic appears to be a vacuum line like was mentioned. It is a hard line, so on the end of it is a short section of normal vacuum hose that allows the hard line to be connected to something else. Double check it to make sure which it is.
'92 Midnight Blue 968 Coupe
Threads: 42
It might be a vac line. I think it goes on the bleeder nipple on the TB.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
It was the line to the throttle body, thanks for the pointer in the right direction!
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Here is a pic of mine, looks a little different than yours. Per flash's comment, the vac line on my throttle body runs back toward the fuse box. Cant see what it is connects to unless I remove the plastic cover. My other line runs from under the intake manifold where the icv is located back to the area around the oil fill cap where it connects into a three prong connection. I think my lines are correct.
BTW, ignore the hook up of the hoses on the TB, car is not driven in freezing weather and I don't want to go off topic.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
What can result if the vac line on the tb is disconnected? Can't really say I had any issues, but have not driven the car much at all the past 2 months.
2005 Acura RL
2004 Toyota Sequoia
