Threads: 1
Cooling sys tests great. Now I know at least the fan is working. just started the final test, Just about finished, when I went to unlock the drivers door with with the led door lock and the darn thing pulled right out of the door. now I have a plastic cap and an led light dangling in addition to a fan relay problem.
1992 Guards Red, Rare White Interior 6 speed, coupe. 130,000 miles. Garage Kept when not running. Anytime there is a problem, $1500 or less fixes it!!!
Threads: 7
John/All,
Thanks for a fantastic write up, John! Due to your work, I was able quickly identity the failed rad temp sensor that was causing my fans to run long after the car was turned off. Constantly having to pull the relay in the fuse box after the morning commute was getting old.
I found the easiest way to change the rad temp sensor was from the top:
<p style="margin-left:40px;">
<p style="margin-left:40px;">1. Remove airbox. (2 screws, 1 bolt)
<p style="margin-left:40px;">2. Remove upper radiator bracket. (4 bolts)
<p style="margin-left:40px;">3. Remove the large rad hose, let the coolant flow into a catch basin. It shouldn't be more than a litre. Leave the small hose attached, it's pliable and can be pushed out of the way.
<p style="margin-left:40px;">4. Unplug the sensor and use a deep 30mm socket to remove it.
<p style="margin-left:40px;">5. Install the new sensor (torque 11ft/lb) and reassemble in reverse. Top up and bleed the coolant.
All in, 45min work, $9 sensor, and an $8 jug of coolant. Thanks again, John! :clap:
Best,
Trent
Trent
1992 968 Coupe Tiptronic
