electrical contact pins
Hi guys, does anyone know the way to pull the electrical pins out of the plastic piece they are in? I have tried to pull them, turn them while pulling out and yet they will not budge. Is there a special tool I need to do this? I have the harness(I think it is called) apart but have to remove the pins that go into each wire for the heated part of the windshield washer nozzle. Thanks so much for any help! this was an unexpected problem also I need to buy new crimp clamps to put on the water sprayer after removing them?
Wow, I'm sorry no one answered your question. I assume you've got it sorted. For future reference, yes there is a tool, but you can do without it. I scoured the web for some good pics, and this is the best I could find, I know it's not the specific connector, but most work the same way.
[Image: maleinsert.jpg]
[Image: locktabchannel.jpg]
You'll notice from the pic that the connectors have a little barb. If you look down the plug you can see where it is located on your connector, then just take a needle or some other small, stiff object and push the barb down as you pull the conductor out the back side of the plug. To replace, make sure you bend the barb back up and simply push the conductor in until you feel it click.
BTW, as long as I'm stealing their pics, I guess I should plug ( [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img] ) these guys. They're great if you need a new connector, or a few pins.
http://www.easternbeaver.com/Main/Elec__Pr...connectors.html
Hey.. great source for some hard to find stuff.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
