Threads: 81
Cheers all -
The supply of these little roof mount antennas is dwindling, and production might be discontinued at some point. I just got one from Neuspeed, who has 9 left apparently. $60, get 'em while you can.
I will be installing mine to see if it clears up my reception issue, and that will be this Tuesday or Wednesday. I'll report back to this thread.
Cheers,
-Mirror
Threads: 81
[quote name='smokiemon968' post='58004' date='Aug 18 2008, 09:37 AM']If you have poor reception, it could be that the antenna amplifier is on it's way out.[/quote]
Indeed. The amplifier on the coupe roof-mount antennas is actually in the base of the antenna itself.
Threads: 81
[quote name='flash' post='58114' date='Aug 20 2008, 05:51 AM']i still can't figure out whey they didn't do a retractable antenna on the 968 - if i had a hatchback car, i would definitely fill that hole, and install one - that or install a windshield with one already in it - they did that on the cab - very clean - why 2 different designs?[/quote]
Don't forget, the "beestinger" antenna was actually somewhat of a styling Vogue in the late 80's and early 90's, so that may explain part of it. Past that, it was probably down to pure production cost; an amplified roof antenna that likely cost Porsche @ $15 was a good deal less than the windshield-separate booster combo.
I could see a retractable antenna, but not if it would have been one of those big, huge yard-long types.....which was the dominating technology back in the early 90's. It would have to be much shorter than that, not sure if that kind of thing exists in an amplified form.
Best,
-Mirror
