Threads: 14
I was cruising home from a golf outing and noticed the "check engine" light was on.I pulled over and shut it off hoping the light would not come back on but it did on restart.The car was (is) running great.All other gauges are normal.It just turned 90,000 but has had recent service.I will drop it off tues. at the P-shop but anyone with any experiences with this malfunction?
92 Black 968 Coupe
2001 Silver Audi TT Quattro Coupe
97 LandRover Discovery SE7 "off road beast"
Past 944s-83,84,86 Turbo,88S
Threads: 25
A lit Check Engine light normally sets a code.
Turn the key on (not run), step the gas pedal to the floor and hold it there till the light flashes a couple times then let it up about 1/4 and start counting the blinks. The codes are all on line (just search for them) and the code retrieval procedure is in the workshop manual
http://www.968forums.com/index.php?showtopic=366).
It's worth effort as you could save the shops cost for diag and repair.
Rick
(This post was last modified: 09-04-2006, 10:48 AM by
968rz.)
Threads: 14
Got the 68 out of the shop.Code indicated 02 sensor but since it was running good they just turned the warning off.Charged me nothing.
92 Black 968 Coupe
Threads: 25
Well that was cool of them!!
I would start saving for the O2 sensor (not that they are crazy expensive), if it set a code once it will do it again; a failing O2 will also affect you MPG (with the cost of fuel now who wants that <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> ). There has been lost of talk about using other than stock sensors. Some say it's bad, some say it's fine, when I was an auto tech we used after market sensors all the time and
never once did they cause any problems, in fact allot of times I would order the direct replacement after market part number only to be sent a universal one (no problem).
Just make sure you get the right kind (heated vs. non-heated). If it's one wire it’s non-heated. 968s are heated, this gets the sensor working sooner for better emissions (have you hugged a tree today? <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> )
<img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
Rick
Threads: 14
Yeah, I take my all my autos(Porsche,MercBenz,VW Passat,Nissan Maxima) to Westport Autohouse in St.Louis.After 4 944's and now this unit,we have become personal friends so they cut me a break on the little stuff.They know they will get it back eventually.With that many cars,one of them is in their shop all the time.
92 Black 968 Coupe
Threads: 25
Start by putting the original chip back in, if the light stays out then you know it’s an issue with the chip, if not then at least you eliminated that possible cause. As for reading codes there have been allot of talk on this, if you do a search for fault codes you should find what you need.
Rick
