DRAIN ON BATTERY
The one about working in a garage
SSTmans post
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Quote:I thought you need several hours of direct sunlight or at least daylight on those units , every day , in order for them to work .. I never thought itd ever work in a garage or carport ..  :o ..  good to know it does .. Smile
I was curious with mine when I noticed the red light coming on with just about any light source. In direct sunlight, it was putting out 1.9-2.1amps. But it was putting out .5 amps in my apartment, with the only light source being my sliding patio door.
AFAIK, .5 amp will overcome any parasitic draw from the alarm, ECU, etc. What it wont do is overcome a dead short somewhere in the wiring.
My car normally sits outside on the driveway, my garage is full of house stuff…. Don’t think a solar cell would really work in a dark garage…! Lol
2008 987 Cayman S Ruby Red
1992 968 Coupé Rubystone Red
1985 924 Coupé Garnet Red (sold)
I drive a '95 968 cab that has a battery drain issue which I suspect may be related to the interior dome light or identical trunk compartment light. Both lights have a 3 position switch, Off, always On, and On that should automatically turn Off in about 20 seconds. Neither light will turn off when switch in in the "delay" position.
My question: What controls the 20 second turn off function of these lights?
The light fixture itself, the trunk or door jam switch or something else?
Any help would be greatly appreciated!
Glove compartment light is a frequent culprit as well
Quote:Glove compartment light is a frequent culprit as well
I can attest to the accuracy as I had this issue.
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
yupp same here a long time ago.
Mine was the hood light .
Thanks for the input, but does anyone know what controls the 20 second delay for the dome light to turn off after closing the door when the switch is in the "delay" position?
Think its the central locking ECU that controls the lights delay
Thank you for your response.
Where is the "central locking ECU" located & how would you determine if it is the culprit, other than replacing it?
Thank you,
RCD7
Not sure where it is on a LHD car, on a RHD its under the floor next to the engine ECU
Last Post by timo944
07-05-2023, 01:55 PM
Last Post by snova
01-20-2021, 03:43 AM
Last Post by tejon007
07-15-2017, 10:53 PM
Last Post by pbc1548
08-23-2014, 10:50 AM
