09-17-2011, 06:45 PM
Over the past six years, I have replaced my ’94 Cab’s battery four times…rather tiresome. After the second quality battery died, began thinking that maybe I’ve got some other issues going on. So, after installing a new battery, I did all the stuff I saw on the posts: checked for drains (nothing); got a top quality trickle charger (a BatteryMinder with a de-sulfanate cycle); checked cables and cleaned all connections; even installed Dan’s (a.k.a successor to IceShark) front mounted ground cable. All fixed, right? Wrong.
A month ago, about half way through a 200 mile trip, going through small towns (lower speeds) I started to see an occasional voltage drop from the usual 13 or so down toward 12.5 or so. Doesn’t sound like much, but when you’re used to seeing no movement, 0.5 volts is a lot. While I got home OK, figured I better load test the battery next morning after an all night trickle charge. Really don’t know why I bothered…I could have just checked my last battery receipt…sure enough, 1 year, 6 months, just like clockwork.
This time, having been smart enough to keep my Interstate 3-year free replacement warrantee receipt, I got a new, free battery with no hassle, other than me having to find an in stock store, install myself in their parking lot (in the rain), and later reset my CR-1 radio code and pre-set stations. Enough is enough!! Time to surf the net…THE TRUTH IS OUT THERE!
After learning about battery construction, proper charging voltages, voltage regulators, and alternator testing, I started researching BOSCH and saw several commentaries about them having been very conservative with their voltage regulator set point of about 13.5V (I’ve verified several times that mine generates about 13.4V). The advantage of 13.5V being very unlikely battery overcharge (boiling, water loss, then death) with any type of battery construction; the disadvantage being possible incomplete battery charging, especially if running lights, radio, radiator cooling and/or cabin ventilation fans. Very troubling, especially seeing much information to indicate that with most batteries, anything up to 15V should be considered quite safe.
Having now decided to install a higher output regulator, but still being a bit uncomfortable with the best voltage set point, I Googled “adjustable voltage regulator.” BINGO: www.davebarton.com. It explains EVERYTHING! Vintage Volvos use Bosch, and have the same problem I’m having, especially in hot weather with the regulator close to the engine (semiconductors don’t like heat). How could I go wrong with a fully adjustable regulator that allows the semiconductor to be mounted remotely in a cooler location??!
So, $55 via PayPal and three days later, I got my kit. Opted not to remove the alternator, but install in place (still not easy, have to do by feel only). Decided not to disconnect battery and only had one very minor "arc and spark." Besides difficulty in getting to screws (a 90 deg. ratcheting screw driver was VERY helpful), ran into one other problem. The sending unit supplied (the brush module) had to be trimmed to fit my OEM alternator.
Encountering difficulty getting the new unit installed (even after figuring out how to retract the brushes with a long, skinny bolt...wow, is that helpful), I compared my OEM regulator to the one supplied. The top profile on the plastic mount is appreciably taller than the OEM. Figured out that the top right side (looking at unit from it's outward side) was lodging against the positive out terminal; that is, with the outboard screw inserted, the inboard mounting hole would not move up to the screw hole in the alternator. So, I did some trim work...needed to remove right top plastic down and just into the grounding strap....maybe 3/16 inch of plastic removal at widest point....left side and center top are OK fit. [This will make sense if you do it!!]
Once the brush assembly was mounted in the alternator, the length of the supplied wire cable allowed me to mount the regulator toward the front of the engine compartment, far away from major heat, and in an area allowing easy voltage adjustment. Now for the amazing part....damn thing worked right out of the blocks!!
My old regulator generated 13.4 volts and not too steady at that. This thing gave me a rock solid 13.8 without touching it. But then you've got to play with it, right? With a running but still cold engine, I started advancing the potentiometer with my "assistant" watching the dash voltage gauge (questionable accuracy) as well as my trusty digital VOM. As I passed 14 volts, the engine became NOTICEABLY smoother! I took it up to Dave’s recommended 14.5 per my VOM while my dash gauge stopped right on 14 (many posts have confirmed these gauges to read about .5V lower than actual).
At 14.5V with no load, I’m now running more than a volt higher than my OEM regulator. Somewhat scary, but as mentioned, I've been buying a quality battery at the 1.5 year mark for the last 6 years. How can it get much worse? AND, everything is running stronger, even my cigarette lighter now glows bright red. I really think, problem is solved. But, I have a major trip planned next week, and need to confirm if I get extended battery life, hopefully 3+ years like my other cars. So, if you don’t see a follow-up post sooner than 1.5 years, “No news is good news!”
