Threads: 147
Ordered a CS Steering wheel from Sunset on Friday... This thing is better then I remembered what a quality peice. It was my favorite mod in my old car it is thick and comfortable. The eargonomics are better then any other wheel I have used. They have the best price by far. Brandywine put another wheel up on ebay today starting bid $375. They had one go up to almost $500 last week. It is silly to watch what people will pay on ebay.
Black 03' Turbo X50
Black 05' Denali
Threads: 147
[quote name='968 Cab' date='Jul 20 2005, 11:29 PM']Eric, what's the procedure to defeat the Airbag warning light when you install the non-airbag CS wheel on a 968 with airbag OEM wheel??
[right][post="7610"]<{POST_SNAPBACK}>[/post][/right][/quote]
Here is the answer via Dave G.
"Cutting the wire completely disconnects the light, so If there is a problem with the passenger system, you will never know it.
A better solution is to put a 3 ohm resistor in the orange connector in the shroud. This fools the computer into thinking there is an airbag still in the circuit. If the light has been tripped, it will not reset it, but it will prevent it from triggering in the first place. "
His way is the correct way... Last time I just cut the wire. I will do it his way this time. Of course you will want to disconnect the battery when installing the CS steering wheel. The install takes about 15 minutes. Tom 944S2.com did a great installation write up. You will also need the 928 part as well.
http://www.944s2.com/how-to/how-to.htm#airbag_deletion
Black 03' Turbo X50
Black 05' Denali
(This post was last modified: 07-21-2005, 03:45 AM by
SANDOVAL.)
Threads: 5
Threads: 8
What wheel is that Anchor? Lokks really nice and I agree with the airbag. Dual airbags is now a requirement for all vehicles in the family. IMHO Life's just too good to trade appearance for safety.
Brian Wilson, Amazon Green Coupe, middle-aged guy from Boston
Home of the World Champion Red Sox and soon to be four time Superbowl Champion New England Patriots. GO PATS!
