Cracked firewall experience/solutions
I have just descovered that I also have this problem. I have added D1R's brace to it, but plan to get the firewall repaired.
Does anyone have pictures of the problem?
Brian
Didn't you just have a new engine installed? Was the problem only discovered after the installation? <img src="/forum/images/smilies/968/ohmy.png" class="smilie" alt="" />
Yes,
Not discovered until they were setting up the clutch...
Trying to figure out a way to repair while using flash's brace.
anyone have DIY solution that works?
Should the brace be enough or does the firewall need repair?
An expense that I do not need/want after the engine and the " while we are in here" bill from my PM.
Brian
I have this problem as well. It came to light when I replaced the clutch. I've installed the D1R brace and that helps. but there is still some movement. My PM says that it requires about 8 hours of labor to remove and replace everything on the front side of the firewall so that you can weld in a plate. The car will be going in to have this done. With the D1R brace in place and a new clutch, I have to depress the clutch pedal all the way to the floor board in order to shift without catching the gears. I have probably no more than 1/2 and inch of travel before the clutch grabs.
Wow, quite a rash of firewall failures.
chris - i'd like to see your clutch and firewall. that is an awful lot of travel. the brace should be limiting the movement quite a bit. that would leave the clutch itself as the culprit there.
05-14-2009, 02:01 PM
Last Post by ldeprat
10-04-2007, 11:01 AM
Last Post by Darryl
12-28-2006, 11:47 PM
