02-27-2011, 11:35 PM
With the help of my very knowledgeable and experienced neighbor, I just pulled the engine out of my car. I did this largely to make it easier to repair the "8-inch gash" in my firewall, which the shop which did the PPI on my car (when I was trying to sell it - changed my mind) claimed was so bad it wouldn't be a good idea to continue driving the car. And they quoted $2000 for the repair.
As you can see in the pictures below, other than it being understandably a little dirty after 19 years, the firewall looks perfect! With the clutch and the front suspension totally out of the car, I unfortunately can't test to see how much the firewall might be moving during the application of the clutch or brake pedal, but the guy who did the PPI was very descriptive about there being an 8" gash in the firewall near the brake master cylinder. I crawled into the engine compartment, to get a closer look, and there's no trace of any damage to the firewall.
I'm going to give the shop the benefit of the doubt and assume that when one of their guys whomped down on the brake pedal with another one watching the firewall, they saw some movement, which is probably typical on these cars, and assumed the firewall was cracked, seeing as this is a pretty common condition.
So, based on what I see, I think all I need to do is buy the standard D1R firewall brace, and have the pleasure of installing it with the engine out of the car. Although I guess this means I also need to also purchase the D1R strut brace, which is a bummer, since I already have a Cargraphic brace, but Flash's is a whole lot prettier. Plus it's a whole lot cheaper than paying someone to weld a gash, and then fabricate some sort of plate.
Any other thoughts as to how I should test the integrity of my firewall with the car in its current condition? Thanks.
(This post was last modified: 02-27-2011, 11:36 PM by Cloud9...68.)
