Coolent in Cylinder 1
I had problem with coolant leaking into Cylinder 1 and it happened recently. It will be there one day but not the other. I had recently replaced the heater control Valve and the hoses between that and the pipes. I check the oil and they are not milky but I saw some milky deposit on the dipstick ball about 6 inches from the end of the dipstick. I just hope this is not a cylinder head Gasket leak!! I had asked and it wil be $2000 to replace it!!
sorry - it is most likely either a head gasket or a cracked head
Perform a leak down test on the cylinder and the radiator.....good luck....
[color="#330099"]SpeedRacer64[/color]
[color="#000"]100%[/color] Pure Stock 1994 968 [color="#000000"]Blk/Blk [/color] [color="#CC0000"]6Sp[/color]
Thats bad news.
I do hope it is a gasket and not a crack in to head.
But I you can do the yob by yourselves it will save a couple of dollars too.
Is it possible that it is oil cooler seals leaking?
SOLD! 1992 - 968
[quote name='timothyleung' post='56483' date='Jul 18 2008, 04:33 PM']I had problem with coolant leaking into Cylinder 1 and it happened recently. It will be there one day but not the other. I had recently replaced the heater control Valve and the hoses between that and the pipes. I check the oil and they are not milky but I saw some milky deposit on the dipstick ball about 6 inches from the end of the dipstick. I just hope this is not a cylinder head Gasket leak!! I had asked and it wil be $2000 to replace it!![/quote]
When I replaced my heater control valve, I removed the oil filter for better access. Did you do this? If so it is possible that coolant entered the engine that way. Just a thought.
Brian
How do you know it's cylinder #1?
[quote name='xrad' post='56506' date='Jul 19 2008, 02:57 PM']How do you know it's cylinder #1?[/quote]
That is the one closest to the front of the car and I removed the spark plugs and only the first one had coolant in it sometime
[quote name='SILVY968' post='56502' date='Jul 19 2008, 10:40 AM']When I replaced my heater control valve, I removed the oil filter for better access. Did you do this? If so it is possible that coolant entered the engine that way. Just a thought.
Brian[/quote]
Yes I did and initially that is what I thought my be the problem as I had to replace the connector hose one at a time as initially I thought only the heater Valve is malfunction but the front hose connecting the heater Valve started to leak after the replacement and then the rear hose did the same thing so I that again. But it had been a month after the replacement and I even changed the oil so that should not be the case. May be I shall do a leak test and see. Head gasket/crack head is something that I wish is not happening!!
Last Post by ste1999
05-18-2019, 11:47 AM
Last Post by banditsc
11-06-2014, 10:39 AM
03-31-2010, 07:27 PM
Last Post by rustech
06-05-2007, 01:12 AM
