Threads: 104
Does anyone know how you input the code in a CR1 or CD2? I have a "9" in my code and with only 6 station selection buttons I'm not sure how that works. Thanks!!!
Threads: 104
Thanks Pat,
That is a long tread so i check it out.
Like I said, I have the code (got it from the dealer), i just don't know how to enter it.
Jeff
Threads: 167
I just bought a '94 968 that the stock Porsche <b><!--coloro:#ff0000-->
<!--/coloro-->radio<!--colorc-->
<!--/colorc--></b> keeps showing CODE on the screen and thus won't work. The supposed code required has a 0 in it, which of course doesn't exist on the key pad (only the numbers 1-6 are available). I was told by Porsche that you have to punch in any number from 1 to 6 and then use the seek buttons to change that input number up or down to get to the 0, but when I try to do this the number never changes from what I originally input. What gives with this <b><!--coloro:#ff0000-->
<!--/colorc--></b>, is it defective or am I not using the right procedure? What is the right procedure? Damn POS...
Put in the number without the 0. That works on my CR-1.
http://www.968forums.com/index.php?showtop...;hl=Radio+Codes
Found using search on 968Forums, where THE enthusiasts meet [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Threads: 30
Jeff,
I seem to remember the CD-2 having two numbers on each preset button.
For example, the first button represented 1 or 2, and the second button representing 3 or 4.
It's been a while, so maybe I'm off base.
Do you have a CD-2, or are you hoping that there is commonality with the CR-1?
If so, are there multiple numbers on the buttons?
Jamie
Threads: 30
A quick Google image search confirms my memory to be faulty. [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
Threads: 104
"Do you have a CD-2, or are you hoping that there is commonality with the CR-1?
Jamie"
I do have the CD-2 and thought the process would be the same with the much-more-common CR-1.
Threads: 30
I never had a problem entering the code on my CD-2.
I still have it in a box with its documentation, so I will take a look tonight when I get home to see if something joggs my memory.
First thing I'll check is if my code numbers include anything above a 6.
Jamie
Threads: 104
Thanks Jamie,
I did find the instruction booklet on a CR1 and it doesn't wrok for my CR2. It did say "code" when i first plugged it in, now it just says off, sure looks nice though!!!
Threads: 30
Jeff,
Looks like your radio is working as designed...
From the CD-2 Owner's Manual:
<i>Should the voltage of power supply to the CD-radio drop below 5 volts due to a dead battery,electrical repairs, or removal (such as theft), the CD-radio will not function when voltage is restored. The Display will show the word "CODE."
The proper 5-digit security code shown on the two I.D. Cards supplied to you must be entered using 6 preset switches (1 through 6) when the CD-radio is turned on and the display shows "CODE." If the correct security code is not entered in the three successive tries, the display will show "OFF" and the CD-radio will not accept entry until the CD-radio has been left on for 24 hours.
</i>
My security code does not contain any numbers greater than 6.
I suspect you have the wrong security code.
Good news is that you have 24 hours to get the right one before you can try again [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
Hope this helps.
Jamie
Threads: 104
<i>"Jeff,
</i>
Hope this helps.
Jamie"
Now, what do you think they mean by "left on for 24 hours"? I checked two Porsche dealers and they both gave me the same code, with the 9 in it!!!
The instructions for the CD2 say nothing special about entering a digit greater then 6?
Thanks everyone for your help.
(This post was last modified: 12-18-2009, 01:23 AM by
jeff968.)
Threads: 30
Jeff,
I went through the whole manual again to look for any sign of how to enter a number higher than 6. No luck.
No mention of it at all.
I checked all of the sections, not just the security code section to see if there was a method to enter a number greater than 6. Unfortunately, the CD-2 has no ability to directly access a track on a CD or radio station by number, or anything else that would require anything above a 6, so there was nothing about it.
Mysterious... and frustrating, considering that you got the code from 2 sources.
With the 24 hour timeout feature it would take 7 years and 37 days to try all of the combinations.
(sorry, couldn't resist doing the math. I know it doesn't help)
There must be a typo in the code numbers. [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
Ugh.
Jamie
Threads: 104
<i>"With the 24 hour timeout feature it would take 7 years and 37 days to try all of the combinations."</i>
Ha ha [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Well, like I said, it looks good!! Even though it just says "off"
Threads: 30
Jeff,
Any developments?
Jamie
