Threads: 9
If your clutch and hydraulics are good and no air, you may try adjusting the pedal.
Nacht Blau 968 cab, Wimbledon Green 993 coupe
Threads: 224
The same thing is happening in my car, but in every gear. yet it's not consistent with my car. Sometimes it returns other times it sticks.
Finally got my car up to the Barn and Pete broke it down for me. I'll try to repeat what I was told. It had to do with a pin that sits between a fork in the clutch mechanism. After sometime that pin gets corrosion/dirt build up and much like a door hinge, needs either cleaning or a bit of lube so as to function smoothly. He has seen this many times and that normally does the trick.
Threads: 167
Its the pin bearings on the clutch fork. Remove the rubber plug from the bell housing (its probably missing already). Spray CRC up there liberally (not WD-40).
Repeat often.
