Threads: 76
Just for a moment this morning. The car was just about fully warmed up and moving when the light flashed. Did not recur. Any reason for concern or follow-up?
I had actually never seen the light in operation in over 45k or driving.
Ralph
'77 911S (RIP)
Threads: 167
Sometimes the flash is in conjunction with another light (i.e. oil)...I would check something simple like that.
The one time it wasn't oil, a vaccuum hose had come loose.
Hope you find it,
Threads: 24
I had a similar occurrence this morning. The car was fully warmed up and I was about 5-6 miles from home. I was traveling at about 55mph in 6th and came upon some traffic so I slowed down and downshifted into 4th (probably should have gone to 3rd as this slightly bogged the engine down.) I gradually accelerated back into the 3-4k rpm range in 4th. About a 1/8 mile later the check engine light came on, no other lights were on. Temp gauge was just under the 10 'o clock, voltage was normal, as was the oil pressure. 1/2 mile (and one stoplight) later the light went off and staid off for the remainder of the trip (another 1/2 mile). I'll watch for it again as I travel home from work. Any ideas on what to check before I leave today? Remember, I am at work and have no tools <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" />
'93 968 coupe Black/Grey, 6 speed, 17" Factory C2 Turbo Wheels, Griemann Grills, and more once funds allow.
Threads: 167
Perhaps not related, but your temp seems pretty high. Mine rarely goes a needlemark higher than 8 O'Clock
(This post was last modified: 03-14-2008, 01:15 PM by
94SilverCab.)
Threads: 24
That's where mine normally runs. In the 9-sub 10 o'clock range.
Threads: 167
[quote name='4matic' post='49259' date='Mar 14 2008, 11:28 AM']That's where mine was till the water pump failed. New water pump. Cooler temps..[/quote]
Yup
Threads: 24
I just had the timing belts replaced about 2 months ago and my shop checked the water pump then. They said it was in great shape. Anyways, thanks for the advice on the temps. I'll check into that.
Threads: 12
[quote name='spectre996' post='49257' date='Mar 14 2008, 10:20 AM']That's where mine normally runs. In the 9-sub 10 o'clock range.[/quote]
Same here for months. Then finally overheated at autox runs. After lots checking and searching it was the pump. The pump axle let loose from the fins. Enough flow for street but not when autoxing. See if enthusiatic RPM raises the temp fairly quickly.
New pump and temps is at 8 o'clock.
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
