Got first piece back from 928leathershop. Here is a pic of center console leather cover with Porsche crest stitched in center. leather looks much nicer than pic (due to sunlight reflection)
Also replaced antenna today. Decided to replace whole thing secondary to corrosion throughout Fuba mount and proximal wiring.
Order $19.99 antenna on ebay. You can just screw in new antenna portion or exchange whole unit and cable. Since carpet is out , decided to do whole thing. Kit come with wiring and connector and antenna.
Wiring a little tricky at corner post(back right), other than that easy. this looks just like original. Mount bolt is a little smaller. Original is 17mm, replacement is 8mm. Fits perfectly once you tuck wire up into roofline. You do have to carefully peel down the roof liner to expose original wiring and to remove retaining zip strap.
