Cab motor cover clips?
Anyone know what clips, screws, etc are used to fasten the motor cover/ rear deck interior lid to the frame? It covers the cab top motors that are located behind the rear seat head rests. My cover sticks up above the head rests and will not allow the boot to install without forcing it into place. Need to know what part it is so I can fasten it so its flush with the head rests. Cant find anything about it. Thanks for the help.
not sure what part you are after but the rear deck trim is held down with 8 clips, 941 504 715 10  they are about $4 each
Thats the one. Thanks!
Be aware, sometimes the clips break because the shelf warps. New clips will not solve that problem.
Good point. Its hard to tell if warped or not. The previous owner had the top bow break. Put the top in manual mode when replaced the bow. Dont know if warped, missing the clips, or installed incorrectly. If warped, does it need replacing or can it be flattened out some carefully via heat gun. Will know more soon. Just didnt want to remove it completely before knowing what clips required to put it back together.
07-17-2018, 07:19 PM
02-14-2016, 01:35 AM
Last Post by Ernie
03-20-2015, 12:02 AM
