09-08-2014, 08:49 PM
Door hinge and pin replacement due to sag. So here I thought I was a experienced mechanic! With over 40 years of hands on experience, 20 years as a tech rep and 15 as an engineer you'd think I could figure out how to change the door hinges.
I could use advise from those who have done this little task...
So here's what I have concluded;
1) The hinge assembly (both halves and pin) were installed befor the door was fully assembled,
2) The original hinges have tooling holes for proper rigging/alignment
3) Porsche did not consider "in-service" repairs as related to the hinges
End result:
1) Lower hinge half to chassis and hinge pin can be removed and replaced. Your gonna need a helper and a rivet gun or suitable tool to drive pin out.
1 a) The lower pin is driven out from the top to the bottom. Not sure why as this facilitates loosing a pin.
1 <img src="/forum/images/smilies/968/cool.png" class="smilie" alt="" /> The replacement hinge half does NOT have the alignment/tooling hole.
2) The upper pin is driven upwards but CANNOT be fully driven out as the outer skin of the door has a fold inwards that prevents this event from occurring. As such, the upper hinge half cannot be extracted.
2 a) Believe alternative is to fully remove door assy, either cut pin to remove and drive pin in to assy from bottom, or flatten skin outward so that the pin can be properly extracted. Glad I will be painting car someday.
End result:
