Car Bra ?
I just received my car bra from Pelican along with my jelly bean welcome pack [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] I was able to get the original porsche bra. The quality looks good. I know some guys mentioned using tape to prevent paint damage. Any tips on installing ? The directions say not to wax beforehand.
Rico Suave
really? that's the first i heard of such a direction - i presume that would be to either prevent wax hazing due to trapped moisture, or to prevent contaminants from becoming embedded in the underside material - i have never had this as a problem though
currently my bra stays on the car - however, i do not drive it in the rain at all, as that would create problems underneath
since it stays on the car, i have installed blue masking tape anywhere there could be rubbing (i.e. across the front corners, between the grill and lights, and across the upper hood band)
do not be surprised if your car runs warmer with the cover on - this is due to 2 things - one is the mesh interrupts the air as it tries to get to the radiator - the other is that the air is generally warmer at the intake point due to the nature of the bra being black
eventually i will get the clear bra kit done, and install that on the car - then i will only use the black bra on long trips
No idea, I am only trained to remove bras. [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
Tom
Last Post by ryker
06-06-2014, 12:30 AM
Last Post by Dirk
12-31-2005, 07:59 PM
