this is a far too common problem, and is very frustrating to hear - you, the consumer, expect you are getting what you are paying for, and in the end you aren't
take it to a different shop - the machine they are using is an old one - newer machines all measure in hundredths of a degree and not inches - also make sure it has been recently calibrated - they go out of whack easily
get a full 4 wheel alignment and make absolutely sure you have your ride height set correctly with the car properly loaded (your weight in the driver seat, normal stuff in the car, and about a half tank of gas) - this job will require some special tools (eccentric adjuster and some thin wrenches)- if they don't have them, they are the wrong shop
get a before and after printout - your current toe is the wrong way, castor is low, and camber is low (should be in the negatives) - that's just the front - any idea what the rear is? that will also seriously affect tracking
www.968forums.com
