968ers,
I ordered the cam chain, pads, seals, etc. for the 968. However, when I took the cam cover off, it looks almost pristine inside. No maintenance history on this car but the primary previous driver traded it in on a Bently, so one might assume she kept it up and at some point the chain and pads were replaced. No real way of knowing I guess. HOWEVER...
1) The bolt holding down the cam chain oil tube was a hex head...not a cheese head...is this normal? (I'm looking for a clue that someone's been in there). All cheesehead bolts are good shape. None buggered up.
2) Cam teeth and lobs are virtually perfect shape.
3) I spent an hour with good lights and Derek Holliday's cam chain check list and all looks perfect except for some VERY MINOR wear on the leading edge of the top tensioning pad (the edge closest to the fender), the rest of the pad hardly shows wear and the wear that does show is minimal at best. The car has 70k miles on it. I just put 3,000 miles on it myself.
Therefore, I'm leaning towards just leaving it as is and checking it every 5,000 miles or so. On the other hand, changing out everything doesn't look like a difficult job but I have a few important questions before I would finally decide:
A) How in the devil does one remove the cams with all the tension on the cam chain? I'd heard of a compression tool or something. How much does it cost? Who sells it? Is it required? There's a lot of pressure there.
<img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> Also, when one takes the bolt out of the end of the exhaust cam, does the cam belt toothed pully come loose too? I don't want to lose my cam timing. Someone had said that if I pick up 3 small bolts (5mm x 16mm or so) after removing the distributor cap, then screw these bolts into the holes that the distributor cap bolts went into, and tighten them down that the the cam drive gear would stay in place while I remove the cams. Am I correct in my understanding?
C) Once the cam chain tension is loosened and the cam drive gear secured, and the cam tie downs removed, and the cam end bolt removed, will the cams just pull out without any special tricks?
D) On reinstall, do the lifters pose any caution/challenge?
Just being cautious on my first time in there. If you've done this before, your response would be most welcomed.
Thanks,
Harvey
