What triggers Radio Alarm contact?
Ever since I pulled my radio to look at it, the alarm led light in the door locking button has started doing the double-flash, indicating that one of the alarm contacts on the car is not closed. What must I do to close the radio alarm contact? The radio is still in and all's hooked up. Not sure what I did to it. Thanks.
Harvey
I believe it is a grey wire in the radio bundle that is supposed to be grounded. You probably have to pull the radio out to see it.
[quote name='Greimann' date='Dec 29 2005, 09:16 AM']I believe it is a grey wire in the radio bundle that is supposed to be grounded. You probably have to pull the radio out to see it.
[right][post="13858"]<{POST_SNAPBACK}>[/post][/right][/quote]
Greimann, You da' man! With the radio fully inserted and solid grounded, all's well again! Thanks, man!
Harvey
Last Post by pte
06-14-2023, 06:33 PM
Last Post by jsheiry
01-29-2020, 05:33 PM
Last Post by Sculler
10-21-2015, 09:07 AM
Last Post by TheJoe
09-25-2015, 10:49 AM
Last Post by daly
11-06-2013, 05:40 PM
