[quote name='rxter' post='52473' date='May 13 2008, 04:10 PM']You talking about the tightness of the top material itself? Should be tight enough to bounce a quarter off of, from the top side. My liner sags a bit but nothing even remotely annoying. Top should be tight. If you can move the top fabric 10 vertical inches with the the top closed and locked, something is bad wrong. I wouldn't drive it with the top closed in that case.
There are some fasteners along the bows that you might check. Other than that I can't think what might make it that loose.
And of course pictures would help.[/quote]
I am talking about when the top is down. I can pull it up by hand a good ten inches. Where before i think it did not move. when it is up it is fine, tight, but i still have a noise.
