Belts!
After (at least(1)) seven years and ~35,000 miles, "Rosa Millard" (yes, named for the Sartoris family matriarch in The Unvanquished(0)) is up on a lift at Dutch Treat getting her belts and water pump replaced, and a look-see to build the laundry list of "what's next" items. (Known: Address the power steering leak; replace the right front sway arm bushing; figure out which sensor is tripping the oil warning light -- oil and pressure are both fine; brake pads and probably rotors replaced; clutch eventually, though it still drives fine it's 95,300 miles old; probably the engine mounts. And then there's the cosmetic -- recovered seats, replacement ragtop possibly with a zip-down glass rear window, etc. Still cheaper than a new Boxster, and room for golf clubs. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> )
While they're in there they're also swapping in the Vanagon temperature switch to kick on the second cooling fan sooner (i.e., before engine temperature climbs to the just-shy-of-overheating tick).
Still mostly commuting on the Ducati, so the Porsche only comes out when I can enjoy her. Looking to buy a condo in the next couple of months, so pouring money into the '68 to keep her as tip-top as possible for as long as possible while everything else settles.
Feels good to be admitted to the Bar finally(2) taking proper care of my baby.
The title of Most Neglected Porsche in a Supporting Role will have to go to another recipient this year. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
(0) The number of times she (and I) should have been defeated... Like when her transmission blew out during a bout of academic poverty; she sat (at $50/month) in a friend-of-a-friend's garage in friggin' Pacoima for nine months until I could afford to have the replacement transmission -- that I lucked into; a rebuilt 6-speed from a builder in Canada -- installed...
(1) I got an incomplete service history with the car, and don't know when -- if ever -- the belts were last done, though since it's a '94 first sold in '93 that I got in '00 with 60K clocked, they have to have been done at some point -- right? Yeah, I should have known better, but I didn't; I'd only ever had Jeep Wranglers before, where maintenance is basically optional and if the belt goes out, all you lose is your radiator fan and alternator.
(2) When I got her I was riding a dot-com salary high. Whoops. Since then I've gone to law school (at night) etc., and am now in a position to pay Porsche service rates again...
Bone-stock '94 968 Cabriolet, '95 Wrangler SE 4.0L, '06 Ducati Multistrada 620 Dark
Practicing law and hacking code in Los Angeles, California (southbay, Miracle Mile, westside...)
cool - long time in the waiting - look forward to seeing it when it is done
Please explain? Is this something many folks have done. Mine far too often gets near the red.
Thanks, Steve
Steve csc71
93 Black 968 Coupe Black Interior, 6sp, low miles
Previously owned a 94 Polar Silver Coupe Black Interior, 6sp
[quote name='csc71' post='32887' date='Mar 20 2007, 04:20 PM']While they're in there they're also swapping in the Vanagon temperature switch to kick on the second cooling fan sooner (i.e., before engine temperature climbs to the just-shy-of-overheating tick).
Thanks, Steve[/quote]
968.net discussion of swapping our temperature switch for that of the Vanagon
Direct link to the replacement part found here
Since the cooling system has to be drained for the water pump replacement anyway, figured now is as good a time as any to have the switch swapped in (it's been sitting on my desk forever, it seems).
Excellent, thanks!
Steve csc71
sounds like there is another problem going on - it shouldn't get that high
the downside to the low temp fan switch for you will be in the winter - if you drive the car when it's cold outside, it may not run warm enough - if it runs too cool, you will fuel wash your cylinders
i have one and love it, but on a really cold day (40 or so), it doesn't get above 180, which is really a bit too cool - fortunately though, i don't drive the car when it's that cold
besides making sure that there is no air flow blockage to the radiator, and making sure that all of the belly pans are in place to maximize the airflow and venturi effect to the radiator, i would check everything else out (water pump, fans, boil out radiator, replace hoses, etc) before jumping into a switch
i know it seems like the quick and easy fix, but it may actually cause you more problems than you are prepared for if everything else is not up to snuff
[quote name='flash' post='32931' date='Mar 21 2007, 08:06 AM']sounds like there is another problem going on - it shouldn't get that high[/quote]
It only climbs that high when stuck in traffic (and, given that this is L.A. ...). When moving at any kind of speed, the temperature stays between the two ticks. But when in traffic it starts to bake. :\ I don't drive it when it's that cold out, either; I have the Jeep for that. The Porsche is a fair-weather ride. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
chris - i was actually referring to csc and the penn winter weather - out here it's no big deal to run the low temp switch
however, it still should not be getting that high with the oem switch, and does point to a restriction or capacity reduction in the system
it could be as simple as a weak tank cap
Steve,
You should definately get Pete to check that out. Might be hoses, might be water pump, any number of things not to be ignored...don't want that to break the week of Celebration...LOL (sound familiar....i.e. me and Mark S last year...)
Regards,
The Bill... Not as bad as could be... $1600 to do all the belts, the water pump + gasket, replace the pulleys (mine are evidently the "original metal" and will be replaced with the "new plastic" parts -- which sounds like a downgrade to me, but I'm not a mechanic <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />) and tensioners, etc., and, [re?]do the service Otto in Venice was supposed to have done in 2000 (my car evidently still has the original circa 1993 fuel filter, spark plugs, etc). That also includes replacing the feed line from the power steering reservoir to the pump, which is evidently "as hard as a rock." Since everything's already torn apart and accessible, they're going to pop the hose in there with no labor charge. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> (Since it's all of two clamps...)
(My PS leak is a weird one... If I drive the car daily it doesn't really leak. The moment the car sits for a few days, though, the reservoir needs to be topped up.)
I'll know more about the PS leak when the car's reassembled. Doesn't *look* like the rack itself is leaking. Next up (not this trip! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />) is the suspension bushings (once I know the PS leak is nailed) and the brakes / clutch.
My boss has an Audi A4 convertible on lease for $830/month. It, while a nice car, isn't exactly exciting to drive, and he doesn't own it (my Porsche is paid for). As long as I can continue to compare service costs to his monthly payment (i.e., I could borrow an Audi for two months, or fix my Porsche for the next 24 <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />), I'm okay... <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Thanks for the advice Flash and Jay...it has unfortunately been too long (due to weather, work, and night MBA school) since I have taken a ride. I hope to get out and about with the car this weekend and will monitor the gauge closely. I had it checked before and everything was normal. We'll see. Thanks again.
Steve csc71
[quote name='csc71' post='33037' date='Mar 22 2007, 03:15 PM']Thanks for the advice Flash and Jay...it has unfortunately been too long (due to weather, work, and night MBA school) since I have taken a ride.[/quote]
Boy does that sound familiar! (I did law school at night.) I think you mean "drive," though; you ride a motorcycle, you drive a Porsche. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[quote name='94SilverCab' post='32936' date='Mar 21 2007, 12:38 PM']Steve,
Regards,
Jay[/quote]
Don't remind me, and I still have a cooling issue of some sort ARRRRGGGGG
Last Post by MLB
02-08-2016, 12:14 AM
09-12-2012, 01:31 PM
05-16-2012, 09:59 AM
Last Post by banditsc
12-30-2010, 01:07 PM
11-17-2008, 12:20 PM
