belts- what I need to change
Hi guys,
I have a 968CS that has about 39,000 miles on it.
The car has been in 'storage' in for the last two years as I've been living overseas for that time. The belts were last changed about 4-5 years ago so I think it's time to do them again.
I've noticed that there are kits for sale online which include belts, rollers etc. for $179. Are these a good buy ..it seems like they are OEM. Kit includes:
Cam Belt Tensioner Roller Porsche # 94410524102
Cam Belt Tensioner Roller Porsche # 94410563110
Balance Shaft Tensioner Roller Porsche #94410227706
Balance Shaft Tensioner Roller Porsche # 94410202507
Camshaft Belt Porsche # 94410532302
Balance Shaft Belt Porsche #94410221904
Is there anything else you guys think I should change in regards to that area?
ps. these will be installed by an independant Porsche service centre.
Regards,
Steve
[quote name='stevev968' date='Jun 24 2006, 11:51 PM']Hi guys,
Balance Shaft Tensioner Roller PorscheĀ  #94410227706
Regards,
Steve
[right][post="23245"]<{POST_SNAPBACK}>[/post][/right][/quote]
Search this list and you'll find a longer listing.
Harvey
Balance shaft seals and o-rings.
It depends how far you want to go. Was the waterpump changed 4-5 years ago (w/ thermostat)? Do you want to replace the front end seals (balance, balance, crank, cam)? Was the balance shaft tensioner replaced last time? Don't forget the accessory belts. There is an extensive list floating around here somewhere. Good luck.
oof - good call on the tensioner - jay just had that problem - big bummer
Last Post by az968
12-23-2016, 12:33 AM
Last Post by MLB
02-08-2016, 12:14 AM
Last Post by MCL968
12-03-2013, 03:20 AM
