Threads: 8
Since that tool is listed as "No Longer Available" people have been using the late model OPRV as the tool. In several other forums they are saying as you are replacing the cover plate you just keep moving the OPRV to make sure it does not bind anywhere as you replace the bolts. Once all the bolts are installed finger tight, check for no binding of the OPRV. If it binds moving it in and out, back off some on the bolts and slightly move the cover plate until the OPRV moves freely and finger tighten all the bolts. Once the bolts are all finger tight check the movement of the OPRV again. You can now torque the bolts to 15 ft lbs.
http://www.clarks-garage.com/shop-manual/lube-01.htm
It would be great if someone has the new tool for them to take all measurements and post so we can have one made for ourselves. You can buy the old tool used up to the 86 944.
Cheers,
Larry
1992, 968 Cab, Horizon Blue
(This post was last modified: 02-17-2012, 07:15 PM by
Grandpa#3.)
Threads: 8
Hi, Sounds great, at least one vendor has the tool. Much better to use the tool than not. Peace of mind if nothing else.
Cheers,
Larry
