Threads: 35
Would someone post a photo or two of the original factory tool kit and its contents? 1994 if it matters...
The tool kit in my current 968 doesn't "look right", but I am going from memory of 6 years ago, so....
I do have a tow hook, and other itmes as usual, but would like to check them off against a known original.
Thanks in advance!
PS: Is there a colored tag attached to the tool bag, and if so what is the color?
(This post was last modified: 10-02-2011, 10:38 PM by
Darth Vadar.)
Threads: 35
Hey super thanks! I have everything you show, except for the piece that looks like an old fashioned drill handle... the item with two 90 degree bends???
What is that and what does it do? Also, my bag is black (dark grey?) with a blue tag on it... so probably not the correct one???
I have the air compressor from Porsche, a plastic sheet, some plastic gloves, but no First Aid Kit and no Safety Triangle...
Could you post a photo of the First Aid Kit and the Safety Triangle? I will probably concourse this 968 and want everything to be correct...
You folks on this forum are super! Thanks again for all of your help!!!
Threads: 35
Wow! Very very cool! I had no idea! It appears that the Triangle is a fold out kind... do you think it came with a case of some sort when new?
And yes, I can't believe the stuff in the First Aid Kit... I have owned five 951's, one 944S, one 944S2, and two 968's, and not one of them ever came to me with the Triangle or the Safety Kit!!! What do the dealers do, steal all this stuff and then sell it on line later????
What time period do you think is covered by the Triangle and Safety Kit??? 1985 thru 1995? Or....?
Threads: 104
I don't think the triangle and first aid kit are original to the 968. There are no references to them in the owner's manual or the PET catalog. Dealer added? I can't tell if you have the small hook for pulling the center cap off the wheel. Also, you need to have your plastic gloves for handling the flat tire and the large plastic bag for storing your dirty flat tire.
Jeff
Threads: 35
Good point on the first aid kit and triangle...
I am going to pass on them, and see if I get docked any points at the next Concourse Event for not having them...
Then, if i do, I will ask to see the reference to such items in the Owners Manual... there ani't any!
That should shake up the establishment! I know some of the newer Porsches, and some older ones, came with the triangles...
Not sure about first aid kits... maybe in Europe and or from the dealer???
Threads: 25
My 93 came with the tools (including the lock cap remover), the rubber and white cloth gloves, air comp and hot sleeves.
It was missing the the bag for the spare and rag (no first aid or triangle kit).
There is some more stuff like the straps to hold the sunroof in the hatch area but that's all I can remember off the top of my head.
Edit: the rag may be the hot sleeve used to protect your forearms from hot engine parts.
Rick
(This post was last modified: 10-04-2011, 07:25 PM by
968rz.)
Threads: 35
My 1994 968 came with the plastic gloves in a packet (as shown in earlier post) and the large plastic sheet to protect the interior form a dirty spare tire, I think!
Also had the Porsche Tire Compressor, and the Tool Kit, less one or two items that I have now replaced. I suspect that Porsche did not always use the same tool bags for every car in the same model year... OI know for a fact that they used up kits in the next year for the 911 series cars, going back into the 1960's....
I would love to have the front and rear engine compartment covers... I am going to call Sunset one of these days if things slow down a bit around here, and see if any are left in stock in Germany... or at any USA dealer? The white cotten gloves would be cool, but not required for the 94 model year. Did not know about the heat sleeves... maybe another european addition?
Threads: 104
If you are including the underhood glove box found on the 92-94.5s in this discussion then there are actually TWO pairs of gloves with the 968. The white gloves in the clear bags with the red stripe in the underhood glove box and the plastic flat-tire handling gloves in the rear comparment.
Jeff
