Threads: 29
[quote name='Langley968' timestamp='1342670182' post='129579']
A previous owner installed an airbag switch on my 968. The little toggle switch is located under the arm rest lid. The only problem is that the "On/Off" label he made is loose, so I do not know which way is "On" and which way is "OFF"!!! Any tips as to how I can determine that? I wonder "why" it was installed, since the car is "stock", other than the stereo...
Easiest way would be to pull out the switch and look at the wiring configuration. One set of wires should be going to a resistor, the other set should trace back and hook up to the orange connector underneath your steering wheel. You will be able to see the connector from underneath the dash without taking out the steering wheel.
1994 Slate Grey M030 Coupe
(This post was last modified: 07-19-2012, 08:42 AM by
blau.)
