AC control panel buttons
It is time to replace the 3 black push buttons on my climate control panel.
The PET shows that the left hand side button is only one button (94465392300), but my control has 2 functions , the button is split into a top and bottom section. One is recirculate and the other half is defrost.
the right hand button is for AC, I believe that that part number is 944-653-924-00.
Does anyone know the correct part numbers for the 2 or 3 switches that perform these 3 functions?
my PET looks wrong.
thanks
brian
If you refer to the instructions / index at the rear of the PET, you'll see that there are actually two part numbers listed, the first as "7" and the second as "(7)" with a denotation in the final column of M573 which indicates the upgrade or option code that uses this part. The parentheses around the second 7 also indicate that the part is not necessarily accurately depicted.
So if I'm reading the PET correctly, the two part numbers for those switches are adjacent in the PET, and are 944.653.923.00 and 944.653.921.00.
got it!
brian
Last Post by MCL968
11-27-2016, 07:01 PM
Last Post by Anchorman
08-08-2006, 10:18 PM
