ABS brakes, seem to lock up first
Hello,
I made a round the block test, the road was wet and I got the feeling that the ABS was locking the wheels for a short moment. There was not the same pedal movement as on my Volvo, when the ABS is activated. I checked the ABS fuses but OK. Have you any input?
Leif
it might have been - it's supposed to release at lockup, but a lot of things will play into that - tire pressure - odd size mismatch front to rear - larger or smaller diameters - water on the rotors
check your pressures, eliminate variables like that - drive it again
[quote name='lampler' date='Mar 22 2006, 12:30 PM']Hello,
I made a round the block test, the road was wet and I got the feeling that the ABS was locking the wheels for a short moment.....
[right][post="17819"]<{POST_SNAPBACK}>[/post][/right][/quote]
I think this is normal for this car. Just a hint of lockup before the system takes over.
Yup, that's what mine does. I wondered the same thing, there's no pedal fluctuation either.
My old Merkur used to chatter through the pedal like there's no tomorrow. You feel it in the Porsche pulsating at the wheels (corners).
Cool huh?
12-02-2020, 04:38 AM
03-20-2019, 01:58 PM
06-16-2017, 09:23 PM
Last Post by Kaj Hallstrom
04-02-2017, 06:34 PM
11-28-2016, 08:34 PM
Last Post by Bulti
02-13-2016, 06:09 PM
