ABS brakes, seem to lock up first - Printable Version
+---- Thread: ABS brakes, seem to lock up first (/abs-brakes-seem-to-lock-up-first.html)
ABS brakes, seem to lock up first - lampler - 03-22-2006
Hello,
I made a round the block test, the road was wet and I got the feeling that the ABS was locking the wheels for a short moment. There was not the same pedal movement as on my Volvo, when the ABS is activated. I checked the ABS fuses but OK. Have you any input?
Leif
ABS brakes, seem to lock up first - flash - 03-22-2006
it might have been - it's supposed to release at lockup, but a lot of things will play into that - tire pressure - odd size mismatch front to rear - larger or smaller diameters - water on the rotors
check your pressures, eliminate variables like that - drive it again
ABS brakes, seem to lock up first - Greimann - 03-22-2006
[quote name='lampler' date='Mar 22 2006, 12:30 PM']Hello,
I made a round the block test, the road was wet and I got the feeling that the ABS was locking the wheels for a short moment.....
[right][post="17819"]<{POST_SNAPBACK}>[/post][/right][/quote]
I think this is normal for this car. Just a hint of lockup before the system takes over.
ABS brakes, seem to lock up first - sasilverbullet - 03-22-2006
Yup, that's what mine does. I wondered the same thing, there's no pedal fluctuation either.
ABS brakes, seem to lock up first - Dave - 03-22-2006
My old Merkur used to chatter through the pedal like there's no tomorrow. You feel it in the Porsche pulsating at the wheels (corners).
Cool huh?
