05-02-2010, 12:40 PM
The car is mostly a weekend driver so it typically sits for five days before I start it on weekends - when I first do that it does idle perfectly right away, but if I give it some gas while still sitting and/or trying to drive it out in the first 30 sec to 1 min after start, it hesitates and stumbles pretty badly. However, returning to idle it's once again as smooth as can be. So I'm guessing it could not be the Idle Stabilizer Valve, or it would have a problem idling as well [img]style_emoticons/<#EMO_DIR#>/huh.gif[/img] The MAF is also clean, so I'm ruling that out.. Spark plugs are firmly in place, as are the wires, the distributor cap and rotor bits and pieces are smooth and shiny, so I have no clue where to look next. BTW, after a minute or so of letting it warm up, the symptom disappears entirely and does not manifest itself again on any other starts during the weekend drives, or at any other times and conditions while driving... until the following weekend when I start it cold again [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img]
